Following replacement of central heating system i am left with remains of old boiler flue which plumbers would not remove as it 'might contain asbestos'. can anyone recommend a reliable asbestos removal service that doesn't cost the earth?
Cremeegg said:For a one off DIY type job as long as you spray it with water and keep it wet there will be hardly any measurable fibre release when it's wrapped up.
i take it you mean on a commercial basis. as (some (so phone before you start)) local tips take it, Im sure DIY is fine, but as always you are liable for the safety of yourself and those around (the risks and precautions have been outlined above).pdcelec said:only a licensed asbestos removal contractor can legally remove asbestos
Indeed........and when I sat @ one during my schooling there were bottles of various acids on the benches in front of us oh, yes and a thing called DisciplineCremeegg said:The boiler flue is most likely to be asbestos cement - same stuff was used to make gutters, downpipes, flat & corrugated roof sheets for sheds, garages and the old heat resisting pads for the ends of ironing boards and school chemistry labs.
