Hi guys,
I have an issue with replacing switches in my dining room since I cannot readily translate the connections from the old to the new switches. I have looked here using search first and have found some answers that come near to my scenario but aren't quite the same. So here goes ...
I have a wall light and a ceiling light. I have a separate dimmer switch that operates the ceiling light and a separate double switch that turns each light on and off.
Current switch wiring is as follows:
1. Dimmer (C, L1 and L2)
There are two cables each with usual earth connections. One has red to L2 and black to L1. The other cable has red to C, blue to L1 and yellow to L2.
2. Double switch (A, A1, A2, B, B1, B2)
As for the dimmer there are two cables each with usual earth connections. One has red to B and black to B1. The other has red to A, blue to A1 and yellow to A2. B2 is unused.
The new switches have connections as follows:
1. Dimmer (L, Sw and a connection with a symbol that looks like a wavy line with an arrow through it)
2. 2 gang 2 way switch (com, com on top and 1 way, 2 way, 1 way, 2 way below)
Any help anyone can give on the correct way to replace the switches would be really appreciated.
Apologies if I have missed a post that already covers this (in which case just point me in the right direction)
