- Joined
- 29 Jul 2023
- Messages
- 11
- Reaction score
- 0
- Country
Hello,
Three weeks ago I started redecorating a bedroom.
I've removed the old wallpaper, cleaned the wall and sprayed Zinsser Bulls Eye 1-2-3 as a base coat on the previously unpainted plasterboard surface. I left the previously painted surfaces as is, just cleaned them with soapy water.
A week later, I applied two coats of Dulux Walls & Ceilings Matt on the entire walls and ceiling, again with a sprayer. I've done all work whilst wearing a respirator. After the job was done, the bedroom door was kept closed, and the window open.
Next day, I came to the bedroom to check the results. I immediately felt a bit dizzy, blood pressure raised, a bit of a scratchy throat and mild asthma symptoms (I've been asthmatic for years). I don't think this was a reaction to the paint as I've painted two rooms before with that one, also with a sprayer.
I removed the old carpet with blots of paint on it and then decided to give the bedroom a week more to ventilate with the window open. Then another week. That helped, but only slightly.
Also, now, three weeks after I applied Zinsser, I can smell the difference between the areas of the wall where it was sprayed and wasn't.
What are my options here, realistically? Remove the paint and the undercoat, with a sander, and repaint? Stick wallpaper on top? I must say I'm clueless as I didn't expect anything like this at all.
