A few years ago a BG engineer "condemned" my dad's boiler for a tiny crack in one of the burners, and said it would have to be disconnected. Another BG engineer turned up the next day to cut off the gas supply to the boiler. Dad said he wanted this second engineer to take a look at the crack because he didn't believe it was really a problem. In the end the second engineer agreed to do this, and decided that the original engineer has been overzealous and that the boiler could still be used. But before he agreed to re-examine the burner, Dad had quite a row with him, during which the engineer said that if he wasn't allowed to disconnect it he would call the emergency service who would come and disconnect the gas supply to the property.
I have only just seen the original notice from the first engineer who did the condemning. I'm trying to understand the terminology. He has ticked the box which says "At Risk" rather than "Immediately Dangerous" He has also written "AR" which I assume means "At Risk" . The boiler is due for another safety check soon and I'd like to get up to speed beforehand. Did BG follow the correct procedure here? My layman's reading of this notice is what they did wasn't right, and they should just have attached a warning label.
