Attaching 3m door frame to RSJ
10 Oct 2009
Renfrewshire
Got a set of 3m folding doors. The frame "needs to be attached to substantial timber or lintel".
Above it is a double layer of PB and an RSJ. Should I attach the frame to the RSJ? If so, how would I do this? Self tapper screw? If so, can you post a link from screwfix? I wouldn't even know what length or size!!
Help would be very much appreciated!
Why is there plasterboard attached to the steel beam?
You will need to pre-drill the steel beam in order to use a self tapper. Get a quality HSS bit. It will take effort but it is doable. The hardest part is keeping the pressure on whilst holding the drill steady and avoiding rounding out the hole through the door frame and making it too 'baggy'.
Don't know about Screwfix supplying, but your looking for self drilling and tapping screws, long enough to pass through both frame thickness, plasterboard and half inch into steel...pinenot :)
Hi all, I am revising this again as it needs done this week.
I have looked for long self tapping screws but no luck. What drill bit would I use?
What do you mean counter bore the heads? Would i need to drill into the RSJ with a HSS bit first before i use these self tappers?
These are the screws you require, no counter boring, pre drilling or anything -
- I told you about them earlier in my first reply. All that's required is a good enough drill and the correct bit for the screw head, they even countersink themselves...pinenot :)
I always drilled fast with a goodly pressure relieving it as the countersinking head dug into the wood...pinenot :)
Yes, drilling the wood is very easy, it then holds the drill/screw in position as you drill into the steel whilst applying pressure. Just make sure you get the right length of screw, all materials prior to steel and 12 mm of thread into steel, they work really well...pinenot :)
