Shower head is:
Its going into a solid wall thats 1 brick thick.
It was suggested that i use a 1/2 inch bsp backplate elbow, sink it into the existing wall to a desired depth, plug wall screw in elbow and then screw head in once tiled.
Seems easy but back plateelbow i have only has 2 screw points, layout
0----0 surely a 3 screw one 0 0, would be better?
the head is damm heavy and its quite long, so produces quite a turning force onto the backplate, with it full of water i dont think the backplate will hold.
It had been suggested to me that if i sunk the backplate into the wall i could then screw in the head, tile over and then the nut could be screwed hand tight onto the tile (giving some support) and then the chrome nut cover could be slipped over that nut.
Looking at the head design, the chrome nut cover is not movable, its designed so that you prob have a plasterboard/aquaboard panel, you cut your 16mm hole, slot head through, chrome ring sits flush on tile, and then you tighten the nut from behind.
BUT as i`m doing this on a solid wall, i cant see how the buggery i`m going to be able to tighten the nut to help give some support.
If i do sink the backplate, screw head in and then tighten nut onto the tile, i will be left witha 5mm gap between the tile and the non moving chrome nut cover/ support.
Please help its doing my fruit in.
