Hi
I am installing a 3metre wide folding sliding door (fsd) into a rendered cavity wall. The lintel is a catnic cavity lintel. The height of the frame is 40mm less than the opening. My intention is to attach a 40mm thick board to the underside of the lintel which I can then attach the doorframe to or alternatively pack out the top runner of the fsd and fix it straight to the lintel
My question is about how I should attach to the lintel? Can i bolt through the lintel into the concrete blocks behind or should I use adhesive? Can I drill the bottom plate of the lintel? Would adhesive be strong enough - especially as the top runner of the folding sliding doors carries the whole weight of the glazed doors.
Many thanks in advance for your help
Chris
Chris
