I'll shortly be attaching some soundproofing board, namely the stuff below:
http://www.ikoustic.co.uk/Brick__Block_Walls/cat857926_1610077.aspx
to my brick walls. The bricks are flat. What I want to know is the best way. The instructions suggest screws with wall plugs, which is fine (dot and dab is not possible as they are too heavy).
Which screws and wall plugs would you suggest? I was thinking of maybe using some frame fixings, but I'm worried the screws might stick out from the plasterboard (which is no good for my plasterer when he skims it).
Please help,
Mr Vander
Please help,
Mr Vander
