Hi, I have an attached garage that I have recently knocked a doorway into via the cavity wall in the kitchen to create a utility/storage room. Now I want to plasterboard the walls in the garage to create a nice finish to my new utility room and hide all the surface mounted pipework etc. however...
the garage floor is 1 course lower than the damp course of the house/garage wall. If I fix studwork to this wall what do I need to be careful of ? I assume that i cannot fix or have any studs touching the wall below the DPC, so do I just fix a sole plate to the floor (leaving a gap between that and the existing wall) on top of some new DPC ? Is there a minimum/maximum width of cavity between the exsting wall and the stud wall ? is there a minimum height above the DPC of the house that I can start fixing studs to ? Is there anything else I should be worried about ?
Appreciate if anyone has any advice on this.
