audio front panel connection probs
10 Dec 2005
Suffolk
hi all anyone help me with an audio connection problem the case is a raidmax and motherboard is an asrock alivesata2_glan.these are what audio header pins are on motherboard pin 1 is mic2-_L ,pin 2 is mic 2_R ,pin 3 is out 2_R , pin 4 is j_sense, pin 5 is out 2_r above these are another four pins gnd , presence,mic ret and out _ret.On the case i have the following wires grnb , mic in which is red wire ,mic power orange wire, L out and L ret double connecter but goes on same white wire ,R out and R ret blue wire same as before double connecter but one blue wire to front .
the gnd is easy and mic in goes to mic2_L BUT WHERE DOES THE MIC POWER GO AND THE L OUT L RET GO AND THE R OUT AND R RET .
ANY HELP WELCOME THANKS
cheers thanks trazor ive posted in the harware section see if i get any replies there thanks
