Auto timing issue
21 Oct 2007
West Midlands
I have a Sabre 24 combi boiler fitted with an external room stat. All works fine in manual mode but if I switch the timer clock to Auto and set the room stat the heating never turns off until the room stat temperature is reached. Is this normal? If not can anyone offer a solution to my problem?
Many thanks!
My point is that is the timer clock is in Auto mode, then the heating should stop working at the set off time. Do I take it from your response that if the stat is set it will overide the timer clock?
ah, i see. you did not expalin your question that well.
no the room stat has the "last word" on wht temp the rads can get up to, no matter what the timer says.
manual mode
ignore what time heating comes on stay on all the time, untill room stat says other wise
auto mode
come on / off at what time the respective on / off times are set for, untill room stat says other wise
Hot water should be available 24/7, since turning a hot tap on tells the boiler you want hot water, it comes on, but will not heat the rads unless it is time to or the timer is on manual.
please also note H/w has priority over the ch
