avanta plus 28c noisy start up/vibration
10 Oct 2013
Cambridgeshire
i have a problem of very noisy boiler - on initial starting vibrates very loudly. gas engineer thought it was the gas valve (gas/air mix) - had this changed - although quiet for a few hours - the vibration is back. any ideas?
Who changed the gas valve?
What test equipment did they use to adjust it?
Tony
gas registered engineer. all readings came in normal range. was quiet straight after so thought problem was solved but on firing up from cold it vibrates very loudly.
did he test it on low & high or just switch it on, it sounds like he hasn't adjusted it properly
