avanti 8
8 Dec 2009
Ayrshire
Hi all bought an avanti compact 8 for a small shop but no install manual I bought this from alert electrical big big mistake, has any one got a copy they could scan and send me
DM
hello again some more info managed to download some stuff on the last sheet there is a diagram which is easy enough but the text states the following
rkp's are wired in parallel, tampers in series using six core, but surely the tampers are internally connected ?no ? or can you wire in more to the T A terminals also are the jumpers left in the unused terminals, this seems to close the circuit and I think of a closed circuit as a completed circuit or are alarm pirs n/c and opened to activate on sensing hope this makes some sense, tomorrow I intend to do a desk top assembly after I fix the daughters car, mow the lawn, walk the dog, weed the garden.
DM
Actually getting somewhere with this, however the strobe/bell seems to have a different wiring set up, the cont panel has two terminals per out but the bell a intellisenes AG6 has one term per function and no return there is a 12v supply neg and pos thats clear enough but as to the rest ?any help will be appreciated
DM
The control panel has the following :
T ..neg tamper return
A..neg supply (perm)
B..bell switch neg
A..pos supply (perm)
Strobe - for strobe.
Page 4 of the AG6/8 guide tells you how to connect , just use the Optima XL4 conections.
Cheers denford I wonder, door contacts I have two sets to fit and no instructions there are two silver screws at the ends which are linked by a resistor? the other three are brass I assumed that when in contact with the magnet portion I would get continuity but alas no no continuity at all any ideas
DM
Have a look in the Alarm Sticky at the top, a magnetic contact is shown , the 2 chrome terms are the ones connected to the glass reed switch , these should go closed circuit in the presence of the magnet,
