- Joined
- 1 Jul 2014
- Messages
- 2
- Reaction score
- 0
- Country
Hi
I have a pressurised heating system. I had a 3 metre radiator in my living room which I replaced with 2 smaller rads at each end of the room. I chased out the floor and used hep2o too connect to the rads.
Yesterday I drained down and hooked up the two new rads filled up and bleed all the rads and ran the system. When the pipes got hot one run of pipe lifted out of the channel in the floor. The pipe is a little too long so I need to shorten it. Didn't seem that bad when it was cool.
The pipe that is too long is the pipe connecting the two new rads together not the pipes that are connecting to the existing system.
If I shut the lock Shields and trv's on both the new rads can I get aways with disconnecting the new pipe and have a bucket handy to catch the water that is in the pipe between the 2 new rads.
I know the you shut the lock shield and trv down you can take the rads off I just wanted to make triple sure before I try and do the reverse.
It took me a long time to drain the system yesterday and I ended up using a bucket and draining from the tails of the old rad. So want to avoid that if possible.
Thanks in advance
Thanks in advance
