B£%%*y plumbers
1 Jan 2007
Warwickshire
Recently moved and needed a plumber to install a shower in an en-suite ASAP. We chose a Roman walk-in shower with Mermaid panels. The little toe-rags put sealant between the panels and the shower tray instead of the proper sealing strip. The result is that it wasn't sealed. I have removed their old sealant, dried it all out and re-sealed again. But still no good. I have now removed, dried again, and placed a very small amount of sealant in the actual gap (1-2 mm) that exists between the panels and the tray, and intend to follow this up with a wider strip of sealant when the first lot has cured.
My questions are :
1. What sealant should I be using ?
2. Not being an avid DIYer what tips can anyone give me with regard to getting a nice smooth finish on the sealant. I've read about washing up liquid etc (which I haven't tried yet) but just using water and a round object (as per the sealant instructions) doesn't seem to work. I get a crap job.
We have since had an identical shower fitted in another room, this time employing a decent plumber, and his work is fantastic and no leaks (but he did use the official Mermaid sealling strip).
All help much appreciated - Scooby
If the first application has sealed the gap, then why add more?
Dow Corning 785.
Which brand did you use?
Less is more. Many experienced people use nothing more than a dry finger.
However, some people swear by the masking tape method. Have you searched the forum?
Softus said:
If the first application has sealed the gap, then why add more? The more the merrier ? Don't know if the gap has been totally sealed until I try it and then if it isn't it's strip it all out again, dry, etc.
Dow Corning 785.
Which brand did you use? This stuff.
Less is more. Many experienced people use nothing more than a dry finger. But it sticks to my fingers and makes a horrible mess if I try that. Have I got the wrong fingers ? :confused: :confused: :confused: :confused:
However, some people swear by the masking tape method. Have you searched the forum? Yes, I have, and the next time I will try the washing up liquid.
One more question please. Can anyone confirm that it is perfectly possible to seal a shower tray with sealant ?
And thank you for replying to my question Softus. I appreciate the help so far.
Scooby.
Not IMHO. Especially since it's the 'extra' that's causing you a difficulty.
I don't agree. If you play water along the joint and look underneath, then you can see where the problem is. You can then dry off that area, and, invariably, finding the crack/pinhole and pushing silicone into it will work.
This stuff.
<image of Unibond Ultimate>
I haven't used that myself, but have heard some people claim that it's OK.
Probably not; probably just the wrong technique. Most likely you're still putting too much on.
More than possible, I think it's the only way that exists.
Wow Softus, now I'm getting somewhere. The reason that I have needed to dry it out was the fact that the plywood (Mermaid) sheeting was getting wet and the "glue" that sticks the individual sheets together was coming out under the sheeting and into the tray.
So I figured that it had to be dried out before any corrective measures could be taken. I have left it for a fortnight without use and have used a fan to circulate the air around the tray during the recent spell of warm weather.
As far as your comments re: putting too much on, I just assumed that more would give a greater degree of "elasticity" for the sealant and would therefore "give" a bit more when someone is standing in the tray.
I still have a lot to learn. :oops: :oops: :oops: :oops: but thank you very much for your help.
Scooby
I think I understand, although I confess I've never seen or used this Mermaid product.
Fair play. But if you test briefly and find just a small leak, then you don't have to be too manic about drying everything out.
Hm. What type of tray is this, and are you finding that it moves and/or flexes when you stand on it?
Thank you. As far as the Mermaid product is concerned it is, in our opinion, much better than tiles. I am told that it is much easier to keep clean and it certainly looks (well to me anyway) much more aesthetically pleasing. However it is a bit expensive but I guess that it is priced in relation to the cost of buying and fitting tiles.
The shower in question is a Roman Colossus walk-in shower and matching tray. I have just enquired with Roman what the tray is made of and they have said that it is a "solid surface" product and they thought !! that it was a "stone & resin mix". I was further advised that any "good bathroom sealant" would be suitable.
I think that all I can deduce from this is that the installation doesn't require any specific sealant. And I don't think that the edges of the tray move very much when standing on it but I thought that I would give it the benefit of the doubt.
Scooby
