My B&D belt sander worked fine for 5-6 years of occasional usage...but recently the belt doesn't keep parallel with the guides and is digging a small grove in the plastic of the sander casing. Re-aligning the belt works for a few seconds and then the belt keeps working at an angle different than 0.
I suspect the rubber cylinder which carries the belt might have loosen its original shape slightly - enough to drive the belt at a different angle...
Is there a way to rectify this problem or I have to look for a replacement?
