- Joined
- 27 Aug 2003
- Messages
- 4
- Reaction score
- 0
- Country
Lighting Circuits:Why is it that every home electric's and D-I-Y book on electric's I seem to pick up doesn't show the way that my house is wired? I'm beginning to think there is a problem the way it's been done. Let me explain; In all the books I've read and seen diagrams of, the ceiling rose appears to be the main junction where both circuit cables and switch cable are present (I think this is called "Loop-in wiring"), or the "Junction box wiring" method, where switch and ceiling rose are fed from the junction box. The "Loop-in" method does away with the junction box.
Well in my house each of the ceiling roses to the light fittings has just one 1.0mm2 cable/two wires feeding them, presumably the "switched live" and "Neutral". Whereas, behind all the light switches there are numerous cables and wires terminating. I can only assume that the switch itself is being used as the "junction box" or "Loop-in?"
Is this method normal? Does it have a special name?
