B&Q Designer Vertical rads - How to bleed them?
25 Aug 2006
Essex
I have installed 2 B&Q Designer Vertical Rads and it seems that they need bleeding, however they don't have a regular bleed valve. At the top of each rad on each side is a 'stop end' which can be opened or closed with a flat head screwdriver.
May seem like a silly question, but should I crack these open to bleed the rads?
Sounds about right to me ;) But have an assistant ready to shut valves quickly if you drop the cap on the floor and it rolls away :eek:
