B&Q Plumbeasy piping - inserts ??
13 Jun 2005
Monmouthshire
I'm fitting a Shower pump using B&Q Plumbeasy 15mm barrier piping.
I've tried searching to find whether or not I need to use Inserts in the ends of the piping, I know they should should be used for compression joints.
But should they be used for the Quickfit push-on joints. ????
thanks
OK,
The reason I asked,
When using plastic based piping for Industrial air systems you only use inserts when fitting a compression fitting using a olive not quickfits.
thanks :confused:
