Back Boiler - Heating, but no hot water?!
14 Jan 2009
Hampshire
I have a back boiler behind a gloworm fire. I have never (lived in house 3 years) had heat in my upstairs radiator until this got sorted on the weekend. A clogged up valve has been replaced and now heat is going to the upstairs rads. New problem is that the boiler doesn't seem to be heating hot water for the taps. The central heating is fine, although seem to get a lot of air in the system and keep bleeding radiators, but it is lovely and hot. Luckily I have an emersion heater so we have hot water for the taps that way.
The pipes leading from the boiler to the tank are cold. Yesterday (after finding something old on this site) I ran all the hot taps and the pipes got hot, but this morning we're back to square one!
Please can anyone offer me any suggestions to get hot water from the boiler again?
Many thanks in anticipation!
Check the F&E tank in the loft has water in it and the ballvalve in the tank is not sticking by moving the arm about.
Could also be a faulty motorised valve or the flow and return pipework to the cylinder might have air in them so will need bleeding. Pipework to the cylinder flow and return could also be blocked but check the tank first, if you have that is ;)
