OK so 2 months ago gas man came round to do some kitchen work which needed gas to be turned off. Then after he finished he went to the old 1950s back boiler to turn it on again but the ignition didn't work.
Asked how the last guy who serviced it (British Gas) turned it on, we said via a match (apparently). He outright refused to do any work on it at that point.
Fast forward to today, the gas is still off (yes no central heating since 2 months ago) and I'm feeling motivated so I took off the front of the gas boiler to find a MESS of dust and cobwebs (I swear British Gas guy didn't do his job cleaning it 2 years ago) and I also found that the ignition switch is BROKEN:
It looks like the metal terminal at the back of the ignition switch snapped off and got left inside the clip above.
My question is do I need to buy a new ignition switch (and are they still available to buy in shops) or am I better off attempting to join the two pieces together with, for example, glue or solder?
Also when I put them together and press the ignition it sparks at the joint, but I don't see any sparks inside the boiler (looking through the glass window). Should I be seeing sparks through the window?
Trying to figure out why the British Gas guy who was servicing 2 years ago didn't fix the switch, maybe couldn't get hold of parts?
Thanks.
Thanks.
