Back filling drains/soakaway and re-laying lawn...
8 Sep 2010
South West Wales
Hi all
We recently had to expose some underground pipes and the top section of a rain water soakaway in our garden.
After reconnecting the pipes, we surround them in 10mm pea shingle and back filled with soil. We also backfilled the soakaway. In both areas the soil is now at the same level as the surrounding grass.
The soil is quite loose at the moment and we are not sure whether to let it naturally sink or whether to compress it ourselves. We don't want to put unnecessary pressure on what is beneath it, especially as the pipes are not very deep at all.
More generally, I also wondered if anyone has any advice on the best way to re-lay the turf (when we did the exposing, we cut out and kept the original turf, which we still have); especially with regard to whether the soil should be loose or compressed (any other tips also welcome though).
Cheers
Max
Anyone got any tips?
(Also, apologies if this should have been i another forum.... I wasn't sure which was most appropriate).
Hi again
Just wondered if anyone has any words of wisdom before i try and do this and (potentially) cock it all up!
Cheers
Max
Hi....
I've just got back from hols so have not got around to dong this yet. I've been advised to compress the soil, then lightly rake it and add some fertilizer. Does that sound like good advice? And if so, can anyone suggest what fertilizer I should use?
Also, do you think I should lay the old turf so that it is flush with the existing lawn? Or should I lay it so that it is proud (to allow for it to sink)? I guess I'm unsure how much further it will sink if I compress it first....
Cheers
Max
Compact the soil with your foot.
Lay the turf slightly proud then pat it into shape with the rear end of a shovel.
