. i have posted this item elsewhere on this forum but a customer of mine is having problems. the cold water tank is overflowing. after changing ball valve i was called back as tank was overflowing again. cold water tank is back filling from cold feed to hot cylinder. house has three mixer taps and i was going to put check valves on hot side of each tap. problem is bath tap is hard to get at and will mean removing toilet and basin. is it ok to put a check valve on cold feed to hot cylinder rather than individual ones on taps or is this a no-no?
cheers
mark
cheers
mark
