This is a two part query relating to stove fitting, I've put one similar post in the section for building control. I already have a stove installed in the living room and it discharges through a stainless chimney liner, all the register plate is fitted and certified etc.
The whole room is looking very tired, and so the fireplace/hearth/mantelpiece/stove is going to be re-done at the same time. I intend to replace the mantelpiece (currently a steel, stone and cement Heath Robinson affair) with something either timber, or concrete but timber effect. Also, I'll have the inset of the "fire place" illuminated with LED strips of spots then re-fit the stove back in the inset and to the register plate.
Electrics in the opening, heat proof lighting/cabling - Is heat-resistance lighting necessary/available? I know heat resistant cable is available, either the stuff for airing cupboards or even the fire alarm system stuff. Are there requirements for the cable type or how it is run? Perhaps using 12Volt gear would negate many problems, or LED strips. (Though I wouldn't expect there to be heat resistant versions of these). I don't want to be doing the electrics myself, I have a reliable and accommodating sparky who I'll get involved with this job, but I want to know in advance what is possible and what is la-la-land. I've seen photos but that doesn't mean it was a photo of an actual compliant and functioning solid fuel stove stuffed into a fireplace.
^^A library picture of the effect I'd like to achieve
Nozzle
Nozzle
