HI
We have a problem with the wall hung toilet in the cloakroom. When flushed there is a trickle of water down the wall under the toilet. Obviously this is coming from either the inlet from the cistern , or the outlet. I think I can check which by chucking a bucket of water down and seeing if the leak still occurs - if it does, then the problem is with the outlet.
Is there a flaw in this theory?
When the toilet is removed (presumably quite straightforward) both connections will come apart anyway. Do they have replaceable seals or joints?
Is there a recommended procedure for fixing this problem?
Many thanks
Caroline
Many thanks
Caroline
