We are refitting our bathroom and need a new shower - planning for a shower mixer with an overhead shower and a shower rail set, all concealed. Found the right combination but am stumped regarding the choice being offered of backflow protection being integrated into the shower mixer or not, so I am not sure which version to buy. It's a hansgrohe mixer "with integrated safety combination EN 1717" or without one, which I found out refers to this backflow protection device (grohe rather than hansgrohe but probably similar) - https://www.grohe.co.uk/en_gb/safety-combination-en-1717-29008000.html.
So, having looked it up online and checked with my plumber I decided to be safe and get the version with the backflow protection despite it making the mixer about £100 more expensive. However, they are also offering two versions of the shower water outlet - with or without a non-return valve, which is presumably the same valve as their "backflow protection" for the shower mixer and which seems to cost about the same except that the one with the valve has a plastic connector rather than metal.
without - https://www.hansgrohe.co.uk/articledetail-fixfit-wall-outlet-s-without-non-return-valve-27453000
with - https://www.hansgrohe.co.uk/article...non-return-valve-and-synthetic-joint-26453000
There does not seem to be such an option for the overhead shower (also hansgrohe).
The plumber says I only need one backflow protector although he's covered himself by saying I should ask hansgrohe, which I have and having got nowhere, I am wondering whether: 1) I need backflow protection at all and 2) if I do, then which one should I get - the one in the shower mixer or in the shower water inlet? Do I need both?
We have an unvented system boiler with a hot water tank and good water pressure.
Would be grateful for any advice - the retailer haven't been particularly helpful either, unfortunately, and I have neither plumbing qualifications nor experience as you can probably tell...
