For at least 8 weeks now we've had an intermittent "bad egg" smell in our kitchen; sometimes it is foul, other times nothing at all. Needless to say we've been hunting around trying to locate where in the kitchen it seemed to be emanating from, but with little luck; we even called out National Grid thinking it might be a gas leak but that didn't indicate a problem (didn't personally think it would as I know the smell of gas; similar, but not the same).
Had a couple of suggestions ranging from washing machine to rats/vermin. I'm guessing not vermin as I had all base boards off and cupboards emptied out and no indication of droppings etc. In addition we have concrete floors with the polystyrene type insulation with a chipboard sub-floor on top on top of which is 18mm solid oak (sure do hope it's nothing below!). I'm pretty sure no soil/waste pipes run underneath the house.
So far we can only say the smell seems to come from ground level and seemingly in front of the washing machine. We tried the usual tricks of running the WM on a boil wash a few times (we have up until now only used cool washes with gel type washing liquid which we now know isn't great for the machine), however this doesn't seem to have necessarily done the trick as the smell does return. Either the boil washes are not enough or the smell just "appears" to be coming from the WM, not sure.
It's starting to drive us mad now so any suggestions or contradictions to anything I've said would be gratefully received.
Regards,
Scott
Regards,
Scott
