Hi All,
I did some painting yesterday on a feature wall Chimney Breast, which is quite a dark brown colour. We originally painted it last Autumn, and then afterwards decided we wanted our TV wall mounted. So the sparks come out, chisel the wall, lay the wires I re plaster the chases and we are good to go - The plaster was sealed with a watered down matt emulsion.
Yesterday, I repaint the top coat. The shop where I got the paint did not have any 1.5" roller sleeves in stock, so I bought a 'mini roller set' for about £2, and the finish I have has got a few roller streaks - the roller itself was leaving a terrible edge, but I tried to make do as it was all I had. Head on, it looks great, but walk into the room and the sunlight hits it and you can see about 3 streaky lines.
I have enough paint for another coat, would buying a new microfibre roller (which I usually use) and giving it a nice thick coat get rid of the streaks, or could I make it worse, so just leave it (the latter is what the misses thinks, but I'm a bit of a perfectionist).
I could probably live with it as it is, but if one coat of paint would 'cure' it, then I would rather do it.
Thanks in advance.
Thanks in advance.
