I have fitted a new sink and a new monoblock mixer tap, and it seems since the day i did this we have noticed a strong taste of tcp in the water,the problem is, the water in the bathroom taps is ok,as we are using the upstairs taps to fill the kettle, so i have re fitted the old tap thinking it might be something to do with the flexible hoses but its still the same, i cant help thinking that it must be something to do with some sort of feedback from the boiler, and that somehow the water from the heating system is leaking into the water , it has been suggested i may have a problem with the heat exchanger, maybe a crack causing the cross contamination, the boiler is a worcester junior 24i combi boiler, this seems a bit of a coincidence this has all happened when i changed the tap but now its all back as original and still the terrible taste then its a real brain ache, so i would realy appreciate if there are any boiler engineers or plumbers that can give me the answer or even a clue to what is going on here.
