In the past couple of months we've had to get the boiler engineer out to fix our boiler. Both times the fault has been the same, the gas valve has been blocked up by a small heap of metal flecks / filings. Last time the engineer had to do this he tapped out the valve over a sheet of paper, and quite a big pile of these metal flecks fell out. He said that this was coming from the external gas supply.
I called the gas board and an engineer came out. He thought it could be coming from our internal piping, but this has very recently been replaced all the way between the boiler and the gas consumer unit. He mentioned that no-one else in the street had reported problems and that the supply was from plastic pipes, so didn't seem to convinced that it was their problem! He said he would report the issue and get back to me - this was a month ago!
Just wondering if anyone else has experienced this?
I've also had a few people mention magnetic filters as a potential solution - but from searching the internet it looks like these are applied to central heating loops, not the in-bound gas supply.
I'm baffled as to where this stuff is coming from! Perhaps it is the pipe that connects our house to the main gas supply in the street? I presume the gas board are responsible for this, even though it is on our land?
Thanks in advance!
Thanks in advance!
