I have a top floor flat (in a block of 4) and am looking to replace the somewhat old combination of storage and panel heaters with the dimplex DuoHeat range. I was thinking of splitting the heating as follows having gone with the dimplex "help me choose":
Lounge - 5 * 3.73m, 1 external wall (fit duo500i)
Bed 1 - 3.75 * 3.6m, 2 ext wall (fit duo400i)
Bed 2 - 4.38 * 3.2m, 1 ext wall (fit duo400i)
Kitchen - 3 * 3.2m, 2 ext wall (fit evx200)
Bathroom - 1.7 * 1.3m, 1 ext wall (fit evx075)
Small hallway 3 * 1.5m (fit duo300i)
I was wondering if there is a better combination that anyone could advise i.e would be a better option to fit the bedrooms with evx200 as this may provide a more instant heat option should it be needed, however once the flat is balanced the need for instant heat may not be required.
Unfortunately I have not experience of living in the property as yet as I am in the process of doing it up before I can move in. Loft insulation will be ~270mm depth in the loft when it's done.
Is my proposal somewhat backwards in thinking as there is gas into the property although my budget is quite tight, the duo option above may be 2k lower than a GCH system so I would prefer the replacement route if I could be sure my calculations are adequate to keep it warm.
