Last year we had a new sandstone fire surround and gas fire installed. At the time of purchase I showed the sales person a photograph of our empty fire opening showing only the start of the existing pre-cast flue (called the chair brick?). This flue is located in a gable end cavity wall.
We asked about abandoning the pre-cast flue and going for a balanced flue gas fire, not only for the increased heat output efficiency but also to get away from what is inherently a less than efficient flue system. We understood that once done there would be no going back. No problem was the answer. The base of the flue would be removed to get access to the outside wall and a lintel would be provided in its place.
The installation went ahead but the installer insisted there was no need to provide a lintel as every above was stitched in to the brickwork. At the time I accepted this but have always had a nagging doubt.
As a problem has arisen with the fire and I am therefore back in contact with the supplier I'd like to get this issue sorted once and for all, simply for peace of mind, but I have no idea whether what I have been told is true or not.
Any comments please.
