Hello all,
I currently am trying to improve the thermal efficiency and comfort level in our our 1920's end terrace. The main issue in our living room is the draught up the chimney. We currently have a high power output open gas fire. However this is useless as the draught up the chimney sucks any heat it produces straight up.
We are planning to replace the fire. The easy option for improving the heat output into the room and reduce the draught would be to get one with a flue liner (current fire is just set into the existing brick chimney.
However I was looking at whether there would be an even better option removing the chimney draught entirely. A Balanced Flue / Sealed gas fire would fit the bill. However these mostly seem to be designed to have a balanced flue routed straight through the wall rather than utilising the existing chimney. I have however found an adapter that allows a co-linear balanced flue stove to be connected to 2 co-linear flue liners http://www.duravent.com/docs/product/L952_W.pdf. Has anyone an opinion on doing this? It would seem like a good option as standard flue liners would be much cheaper than running a balanced flue the whole way up the chimney, if that would even be possible.
