Hi guys I previously thought that the balancing valve on the flow side of the HW cylinder was intended to ensure a shared flow the the HW and CH systems when they are both active, however, it occurred to me that the flow temperature through the W cylinder will affect the return temperature and thus the modulating on the boiler.
Is it the case that I ought to balance the HW valve so the return of the HW cylinder is 14 degrees lower than the flow?
