Some months ago I had a problem with my heating system - newly installed Vaillant 828 combi would heat up to 80 then immediatly cut out without radiators heating up. Same cycle would then continue. A friend checked the boiler and found that the water was circulating through the diverter valve(?) but not through the main pipework. I got a firm in who cut out and replaced pipework near my former HW cylinder (+ filled system with inhibitor) and, hey presto, the rads would then heat up. However the bottom of the rads is always less hot than the top which I presume was because of sludge at the bottom? I've recently replaced two rads but, from day 1, they also do not get as hot at the bottom as at the top. I've tried balancing the system and can get some rads hot at bottom but other rads then get cooler. Should I continue with endless balancing or does the whole system need repiping + new rads in order to cure this problem. (incidently the boiler is sited on ground floor but pipes up to first floor rads before splitting up and down to grnd fl rads and 2nd floor rads - any implications?) It's mostly ground floor rads that have the problem.
Any advice appreciated
