Hi
I have a recently installed system boiler (Worcester Bosch)
When I remove the heads from the TRVs I can get all of the radiators balanced with a 12 degree drop between flow and return - I know some may disagree with the 12 degree drop but my common sense logic tells me that whilst it may be incorrect, the fact the drop is the same across all rads then the system is balanced? All rad temps are pretty much identical as well.
When I fit the heads to the TRVs the house doesn’t get anywhere near as warm, even with them on maximum almost like they are closing too early?
