- Joined
- 17 Oct 2005
- Messages
- 171
- Reaction score
- 2
- Country
hello all can I have some advice / experiences please.
if a radiator is cold/colder than the others on the system would I be looking to open the return lockshield valve more, or less?
all rads have thermostat valve (TRV's) on which is turned up to highest (5) and radiators all bled so its no issue of air in the rads.
at the moment I have each lockshield valve turned about 1 full turn from the closed position, because if I new which was the last rad I was going to gradually open up lockshield valve as I went along and fully open the last radiator on the system. - I cannot tell which is last or first radiator on the system because all the pipes are buried under the floors and they may have been installed originally in a back to front way .
I havent got any temperature thermometer thing for the flow side so I am just touching with my fingers until I feel heat coming through.
Thank you.
Thank you.
