So i want to re-balance my rads generally, as over the past couple of years a few have been replaced/added. The slight issue I have however is that the coldest room (lounge - so the one we would generally want to sit when the heating is on during an evening) which just happens to be furthest away from the boiler also has the largest radiator, and this also happens to be the one which is slowest to heat-up, as well as being very slightly cooler at the bottom than the top.
The valve is fully open on this rad, so I have no wiggle room there to make any further gain. If I was going to balance eveything I would use the 'standard' 20 degree flow/return method starting nearest to the boiler, but my question is:
If I find all the other rads (which get plenty hot btw) are balanced, how do I make sure the lounge rad gets a disproportionate amount of heat so warm quickest (or at least as quick as the others)??
I could always balance all the others, then close them off 1/4 or 1/2 a turn for example, but that doesn't seem very scientific. Is there a way of say balancing the largest with a 20 degree flow/return difference, but use a different temp difference for the rads which are nearer the boiler?
