To get the l2 deg. differential betw. flow & return of the nearest rad to the boiler the l/s valve has to be almost closed, at which point there is a whistling/hissing noise. Any suggestions? Is the differential supposed to be constant. It seems that at first there is a huge difference (at the boiler as well) but after the heating has been on a while the gap closes.
I have been reading some old posts re radiator thermostats and digital devices,l infrared pyrometers. Do I understand that the laser things only work on painted surfaces? If so, what do I do about the unpainted pipes in the cellar if I want to check the differential there? The clip on thermometers aren't accurate.
