Thanks all for the replies.
D_Hailsham said:
No my mistake, it's a sloped ceiling. 7' at one end and 13' at the other.
D_Hailsham said:
Check if there is any insulation under the living room floor. You can check from the garage, though it may mean removing some plasterboard hiding the joists.
I haven't been able to check. The garage ceiling is boarded and plastered.
TicklyT said:
Is the thermostat in the living room, or is it in a part of the house that warms up quickly, and shutting down the heating before the living room gets a chance to warm up?
The thermostat is in the hallway, which is the part that heats up quicker as you say. The rads in the living room aren't shutting down too soon. They are too hot to touch but still the room is cold.
ajrobb said:
What radiators do you have in there? (number, lengths, heights and panel types)
How many outside walls?
Age of building and type of construction?
2 rads, they are both the double finned ones and are 60cm high. One is 190cm long and the other is 95cm long.
The room has 3 external walls. One with a large window, one with patio doors and one with a chimney!
The house was built in 1982 and is brick and part weatherboarded.
ianniann said:
Even regular sized single glazed windows are likely to be the biggest single heat loss from a room. Over-sized windows plus patio doors are the first place to look for your cold room even if the walls are insulated. The open stairwell (no doors?) won't help either. The ceiling is the roof, I assume? Top floor rooms also have higher heat loss, very high if the roof space isn't well insulated. Being over the garage may or may not be a problem. I'll suggest not a massive problem unless you have serious drafts coming up through the floor. Might be the cheapest one to insulate though ...
The window is 230cm x 130cm. Patio is 230cm x 190cm. Rad sizes as above. Yes the ceiling is the roof. The loft has insulation but the loft does not extend over the living room unfortunately. Entering the room bare foot, the floor temperature is very noticeably colder than the other rooms, although holding a candle to the windows does flicker which tends to implicate the windows.
I'm reluctant to rip up the living room floor or the garage ceiling if it can be avoided. Would it help if I covered the garage ceiling in PIR insulation board? I could do that myself. Otherwise I could get someone in to squirt something into the cavity if its not been insulated.
If I'll get more benefit from improving the windows I could get them replaced. The house will need double glazing eventually, they are wooden frames. Having moved recently I can't get the whole house done at the moment but could probably afford to get the living room window and patio doors done.
Would be good to get some more clarity on the main cause of the cold though.
