I have an open vented system with 17 radiators. I replaced some of the valves a couple of years ago with TRV's, replacing each main valve. Little did I know that when the house was built 10 of the radiators were installed with the lock shield valve on the feed side of the radiator. The TRV's I fitted are bi-directional.
Question is, is it possible to balance a system like this or will the valves have to be swopped on the radiators that are wrong?
To make matters worst the radiators are connected using micro bore, 8 mm for upstairs and 10 mm for downstairs. The Danfoss trv's I fitted will not simply swop ends as the back nut and olives are totally different. My worry is that if I have to change the valves I will have to renew the micro bore at both ends but there is not a lot of room between the wall and centre line of the rad valve to get an inline connector and an elbow in.
