Hi all quick question.
I have a header tank in the loft with an immersion heater in the bathroom.
Noticed no water at all coming from the hot water taps the other day.
Checked the header tank and the ball valve in the header tank was stuck in the closed position.
As I opened the lid without touching the ball valve it lodged itself open.
It has been working fine since.
(I had changed a cold water tap the previous week and turned off the cold water could there have been a air lock in the cold water supply to the header tank?)
My 3 questions
1) Is this a common problem, last week was exceptionally hot could this have caused it?
2) With it working fine does it need further action?
3) If it happens again and my immersion tank is empty, if the coil comes on is there a risk it the immersion tank could blow up?
thanks for your advice
My 3 questions
