Ballast question
26 Jan 2016
I want to lay a thick concrete slab(600mm in places) as a shed base and intended to use a maxibag of ballast and cement. Many builders merchants seem to offer only ballast with small stones. More like a very coarse concreting sand, such as this from Travis Perkins
https://www.travisperkins.co.uk/Travis-Perkins-Sand-and-Stone-Ballast-Bulk-Bag/p/938169
Is this really as strong as sand and gravel, I was always under the impression that it was the gravel that gave the concrete it's strength.
The ratio of large aggregate to smaller fines in concrete affect its strength.
Ballast should have a good mix -usually with bigger stones upto Id guess 40mm and small stuff.
I n the context of a shed I cant see it making much difference.
Pumped concrete only contains small stones.
No, 600mm is correct. It's a foundation for a telescope pier. Most of the shed base will be around 100mm thick. But part of it will be 900x900x600
Thanks for the replies everyone, probably going to go for the Travis Perkins one
