ballcock sticks to flush unit
14 Nov 2012
I changed my flush unit and now the ballcock arm sticks to the flush unit. The arm is made out of some iron.
Can the ballcock arm be adjusted? Or would I need to buy a new ballcock arm and fittings.
Thanks,
Mamaji
Bend it abit so it don't touch.
Is this a new flush unit or just a replacement ?
Thanks for the quick response. I did try to bend the arm, but it seemed pretty solid - or maybe I need more protein :)
It's a replacement. Fits and works fine.
I'm not sure if the arm comes off? If so maybe I can try bending it in a wrench.
The toilet is 10 years old. Would buying a replacement ballcock unit give me the same problem?
If it's a replacement didn't it hit the old one ?
The arms useally held on by a split pin.
Well yes it'll be the same.
Can you not give us an internal pic of the cistern ?
Nope - no issues with the original.
Will have a look and try.
I'll do that tomorrow morning, on the train back home at the mo.
Blimey, 60 posts and still can't get it right. :rolleyes:
Anyway, Mamaji. Take the syphon out and put it back at 180 degrees from how it is now, then fit a Fluidmaster inlet valve in place of the ball cock.
Is it a side entry, or a bottom entry cistern? It's not really clear to see from the angle you have taken in that photo.
Taking out the syphon and rotating it 180 degrees won't work unless there is another hole on your cistern on the left hand side for the handle.
The Torbeck is extremely small. There is a newer version out now which is bigger, and possibly has a longer life, also a version of the Fluidmaster which is available with a brass stem, rather than plastic, and is less easily damaged if you are clumsy with the spanner. I like the old Torbeck as shown, but they are prone to grit or dirt collecting inside, and need to be unscrewed and rinsed in clean water when this happens (usually after the water has been cut off and limescale has washed into the pipe). This is no trouble as long as you have a service valve nearby to turn the water off. I think my oldest one is about 24 years old now and still working fine.
You will find either the Torbeck or the Fluidmaster very much quieter than your old valve, for this reason I always use them now instead of the old type with a big round float.
If the syphone is very awkward, you can remove it and replace it with a Flapper http://www.wickes.co.uk/invt/424925 valve, which takes up hardly any space and gives a quiet, powerful flush, or a modern Fluidmaster flushing valve, which you can often get in a set with the filling valve.
It is more work to change the flush, as you have to take the cistern off, and the fixing screws are probably rusted solid, unless the previous person was thoughtful enough to use stainless.
You will find the parts cheaper at Screwfix, eithe mail order, or collected from your nearest store. http://www.screwfix.com/search.do?fh_search=fluidmaster&fh_view_size=20
It's a bottom inlet entry
Taking out the syphon and rotating it 180 degrees won't work unless there is another hole on your cistern on the left hand side for the handle..
I don't have an option to change sides sadly, just have a right side handle :cry:
