Balustrade renovation
16 Nov 2007
I recently moved into an Edwardian house in need of some TLC and high on the list is repairing the balustrade. In addition to stripping and sanding the lot there is one snapped baluster which I hope can be repaired rather than replaced.
But the main concern is it's no longer securely fixed, it wobbles and the cause of this is the loose newel at the bottom of the stairs. The base of the newel is square, about 8 inches by 8. This square section runs for about a foot to floor level from the end of the turned, main section - I'm not sure if this is a separate spigot or whether the whole newel is built in one. If it is a newel and spigot then they are still securely attached to each other and it is the spigot that's loose.
Anyway, the wobble starts below floor level. There is a wooden floor covering over the hall floor boards that I am reluctant to lift so I haven't investigated what's going on below the floor boards.
Any suggestions on how this should be secured and how I can fix it.
Many thanks,
Jim.
Nicest scenario is the joints have become unglued and worn. Needs regluing and screwing.
banisters fit into newel posts by means of a bolt look under the banister nearest to the newel it could do with a good tighten.
or
Could be rot or woodworm.
Check for rot especially at the base of the Newl post.
and woodworm under the stairs.
Cut out and renew effected timber and treat remaining timbers.
Hope its just wear and tear
