Bamboo hardwood floor
30 Dec 2005
Staffordshire
We are thinking of having a natural bamboo hardwood floor, anyone fitted one? and do you think the colour would look ok with an medium oak coloured kitchen?
I have read about putting a plywood floor first is this essential does the floor need a membrane down first to do this or can I put the bamboo floor onto the foam insulation.
The colour you chose is up to you. If you like it buy it! If subfloor is flat (2mm in 1meter for floating) then you dont need ply. And i take your installing over wooden subfloor so no moisture barrier underlay should be used. Again i will let you decide which one. Depending on where you buy from they can normally advice you the basics on underlay unless your shopping at [/b]um............ um.............. to go...... or somthing like that , as you will have no chance of leaving there or simular place with the correct product.
We got a few free samples from companies off the net, might help in choosing.
Where you going to pick horz or vertical pressed bamboo as the vertical although looks great on the pics when you see a sample and imagin it across your room i think it looks very busy.
We have opted for oak in the end, i found a nice ebay shop selling nice qualilty wood for about the same price as bamboo flooring and would probably suit your kitchen better.
Although again all ones person point of view
Type hard wood flooring in ebay and the company is based in deeside in north wales dont want to give the name as not sure of post rules. But they are priced very reasonably. If you need anything futher drop another message
