Hi, I live in a house with a very old CH system and boiler. The system seems to have 22mm pipes with 10mm pipes tee'd off to the radiators, therefore as I understand not a proper microbore system and also not quite conventional ie 15mm to the rads. During the winter we put the CH on constant and the HW on timed. The boiler is situated in the downstairs loo, with the tank, pump and 3 way upstairs in a bedroom cupboard. Last year I changed the 3 way valve and the circulating pump, the 3 way was completley seized, I flushed the system with some leave in chemicals for 6 weeks and then filled the system with some inhibitor added. Prior to this and still the rads in the front of the house do not get as hot as the others. I have just removed the rad from our bedroom expecting it to be really sludgy but it wasn't. The pump was running on its lowest setting, if I run it on the highest setting the cool radiators get hot, however when I do this there seems to be a problem when the hot water comes on. It is as if the pump is too powerful for the valve or the valve is too slow to operate. The pipes all start banging and clattering from anywhere between 3 and 15 seconds. Does anyone have any ideas to help me sort this out please?
