- Joined
- 18 May 2017
- Messages
- 1
- Reaction score
- 0
- Country
I had a leaky tap so I had a plumber change the tap for me, but now if i turn on the cold water I can hear a pipe banging. It doesn't happen when the hot water is turned on, or if the cold water tap is turned on gradually. The plumber said that this is most likely caused by pipes that aren't secured properly (1920's house).
The old tap was ridden with limescale and as a result was quite stiff to twist, so I'm thinking the reason it didn't bang before it because it was stiff and gave the same gradual turning that I have to do now.
The problem is that because the tap is new, you can pretty much touch it with your little finger to turn the tap on quite fast which results in a 'bang'.
I tried reducing the pressure using the main stop, but I can still hear the bang, and reducing it too much felt like there was too much pressure because the flow was reduced if that makes sense.
Is there anything else I can do to stop this bang without ripping open the walls to secure some pipes all because of a leaky tap!
