i recently had a leak on one of my pipes fixed the leak with a new peice of pipe but now i have a banging pipe .its on the pipe that comes into the house [supply] tried bleeding the rads but still there any help would be apprieciated thanks
thanks tried turning down the supply still get baging but not as loud replaced all the clips when i did the job .
is it air in the pipes or should i try more clips
