Hi
i've got a indesit w131 washing machine that makes a very slight banging noise while in normal use but a very loud banging noise while on spin mode.
i did a search on here so have checked a few things:-
. took back cover off and drum was not banging on side of machine on spin cycle
. if i reach inside the drum and put 1 hand in the middle at the top and 1 at the middle at the bottom i can move it slightly up & down. if i push it up and down from the front of the silver drum i can rock it up and down a fair bit . it doesn't make a banging noise if i spin it by hand
. the top counter weight is bolted securely
. the filter had a vey small amount of grey gunk in it
the banging noise seems to be coming from between the 2 drums. is it an easy job to check between the 2 drums? the machine is about 5 years old so if it is uneconimical to repair i will have to get a new one
thanks for any help
thanks for any help
